Injected with a poison
Have any of you had a problem with the 1 - 2 upshift on your R6?
more often than I'd like, I find on acceleration (hard, or otherwise) that sometimes the lever will flick into neutral instead of going right into 2nd.
The result is a nerve jolting rev spike, because I am twisting the throttle in anticipation of everything working the way it should.
I can understand that perhaps there is more travel needed in the lever to make the shift from down 1, then up 1.5, or 2 to get into second gear, but I am not doing anything different in terms of my shifting habits.
I am just wondering if there is a synchro issue here, or if my set up needs some kind of adjustment.
It's irritating to say the least.
Thanks!
what year bike? Do an oil change.
you can adjust your shifter, but what i noticed is that my bike likes to shift at a certain time. if i shift early or late it can be stubborn. try revin up a lil more before 2nd and see if you notice anything
GP-Shift. Once you switch the pattern, you will NEVER have that problem again.
If you are unfamiluar, a gp shift simply switches the shift pattern around. 1-up, 5 down. This is the way it was suppose to be IMO!!
Depending on the year of your bike, it's a easy/cheap mod.
Check out Woodcraft gp shift rod. $25.
