Can I put a 5 spoke front wheel from a 2005 on a 06+ R6 (inverted forks)???
also note, i know the R6s rims will not work due to smaller rotors 298mm vs 310mm if i remember right.
BUT could I mount the 310mm rotors on the R6s rim (do they have the same bolt pattern for the rotors?) Is the rim the same other than the rotor size?
^s Own The Messagenet
05 and 06 share almost the same front end.
