2003 Yamaha YZF R6
My battery has lost its charge. I replaced the battery and it happened again. When I began looking at the charging system I found that there is a hole burned through the plastic conecter from a phase one wire to the black ground wire on the dc side of the rectifier. I am thinking it is just old plastic but I want to make sure there isn't anything else that could cause it to burn straight through. I have performed all the continuity tests to the stater (everything reads 0) as well as the diods on the rectifier (reverse and forward all good). There is no corosion or open wires that I can see. The phase one wire is arcing with the ground wire inside the plastic clip where it burned straight through.
Thanks in advance.
Food Recipe Ingredient Staple food Finger
