So I'll cut to the chase. I have an '03 R6. After the bike warms up it's hit or miss as to whether or not the symptoms occur.
But here are the symptoms:
I got this bike used and it started giving this problem around late October/early November IIRC; I got it in September 2019. As for the Yoshi, I got that put on on Sept. 26th if that's relevant.
The problem was never this bad but it has progressively gotten worse. I have provided as much info as possible, but I can also get a video if I check my GoPro footage for it. Any ideas on what it could be? I'm really tight on cash so I'm scared to take it to my mechanic for labor charges.
- Idle gets extremely rough and if throttle is let go in some cases it will simply die (bike struggles to stay alive pretty much)
- There is a VERY strong smell of gas initially, can sometimes last a while
- The exhaust can shoot flames very easily (only after releasing throttle though, so I don't think it's backfiring but I'm also inept when it comes to the terminology)
- The pops it does are can be very quick, and very powerful, moreso than usual, to the point that my parents thought a gunshot went off in the back of the house
- Power becomes steady above 5k, but prior to that (such as holding the throttle steady at 4k) the bike will sort of go bUMbUMbUM in a slight lurching, inconsistent manner
- The closer to 5k the more moot the previous point becomes
- After 5k the problem doesn't exist
- In some extreme cases I can pull the clutch in while riding and the bike WILL shut off
- Replaced the spark plugs
- Checked the ignition coils
- I did a resistance test. Primary was fine and all of them were around 5.1kOhms except for one at 5.6kOhms. This was still within spec.
- I did the "water evaporating" test on the headers, and the first and last evaporated slowly. I switched the coils and the same pipes remained slow to evaporate. That makes me think either this is normal or it's the wiring subharness?
- These are not Denso coils
- Changed the oil
- Fuel stabilizer
- Replaced the R/R (I had a code 46 at one point and that was an issue, diode test failed)
- Checked stator for resistance, continuity, and AC volts; checked fine
- Around 41k miles
- Valve adjustment done at 36k miles
- Yoshimura Slip-On exhaust
- Changed the spark plugs
- A snazzy R6 brake reservoir sock on the front reservoir (I wish this were the problem)
