1 - 7 of 7 Posts
I have a set of slide stops that will fit 03-04 r6 maybe 05 to but check with graves on it. The are new and never installed comes with instructions and fuel pressure booster. I do not have the floppy disk with the map on it for these but you can just get the map you need off of the board. you must have a power commander to run these. $60.00 O.B.O SOLD
I also have a damaged headlight assembly for sale. The left side lense is broke and the housing on the left side has some parts of it broken (check out pics email me or pm me for more). Both of the PROJECTOR ASSEMBLIES ARE PERFECT. I was going to use this to mod up my headlight but I just traded my 6 up for a r1. $150 O.B.O
I believe graves has different slide stops for the 05 because it does not need the pressure booster that the 03-04 does. I am not sure if the slide itself is the same for the 03-04 & 05's
1 - 7 of 7 Posts
