Please help bike won't start/ turn over - R6Messagenet.com
post #1 of 12 (permalink) Old 04-12-2011, 05:15 PM Thread Starter
Hi guys
Just picked up a 2002 r6 it won't start on the button just a clicking under the seat. Has a new battery but the starter motor does not engage. If I rock the bike back and forwards in gear it will then start, could it be the starter motor
Bolen211 is offline
post #2 of 12 (permalink) Old 04-12-2011, 07:30 PM
Garage
Even though the battery is new it may need a charge. My bike was making the same clicking noise under the seat as well when I couldn't get it to start. I gave it a boost and started up no prob and haven't had any problems since.
John Pirone is offline
post #3 of 12 (permalink) Old 04-13-2011, 03:29 PM Thread Starter
I put it on charge but still no joy, if I rock it in gear it will start!
Bolen211 is offline
post #4 of 12 (permalink) Old 04-13-2011, 05:07 PM
Garage
don't know... maybe try posting on the tech page. Good luck
post #5 of 12 (permalink) Old 04-14-2011, 09:36 AM
Lifetime Premium
chidadog's Avatar
Check the tip sensor. But sounds like a bad starter or dead cells in the battery. Try jumping it at the solenoid. PM me if you need more info.
chidadog is offline
post #6 of 12 (permalink) Old 04-17-2011, 09:29 PM
it could be a bad starter, or going bad, but also the noise sounds like a dry start which is caused by a bad battery, and although you charged it it may have dead cells and not holding a charge...
yzfr6gm is offline
post #7 of 12 (permalink) Old 06-18-2012, 07:05 AM
I have the same problem. was it the starter?
My battery is good and most of the time it will start the bike.
It has happen twice(early morning when i need to be somewhere), when i try start the bike. It it's like the starter motor jams up. press the start button and it just makes a noise but doesn't turn.
If i put it in gear and push it back and forth it drags the rear wheel, it doesn't roll. So i push it back and forth in desperation and tried again both times it worked after this...(eventually)
Any ideas?
KILBURN is offline
post #8 of 12 (permalink) Old 06-19-2012, 01:00 AM
put full charge on the battary my cousins bike did the same ..
plainandsimpo is offline
post #9 of 12 (permalink) Old 10-08-2012, 02:46 PM
Hey I just got a 2003 r6 and as I was readying it home from buying it and bogged out ..I tried to start it again and all I get is a single click fromt the stator relay ..the instrument panel dossent dim when trying to start no error codes come up ..It has a power commander but I took it off and still get a click
R6stuntin88 is offline
post #10 of 12 (permalink) Old 10-10-2012, 07:14 AM
The blue R6cer's Avatar
Garage
The Reg/Rec may have given up the ghost.
The blue R6cer is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
You may post new threads
You may post replies
