Originally Posted by buckeyefan
The GT is a different test that the ASVAB the highest you can get on the ASVAB is 100.
No, a GT score is a part of the ASVAB. There are individual sections of the ASVAB that are scired differently.
The ASVAB contains nine sections:
General Science (GS)
Arithmetic Reasoning (AR)
Word Knowledge (WK)
Paragraph Comprehension (PC)
Mathematics Knowledge (MK)
Electronics Information (EI)
Auto & Shop (AS)
Mechanical Comprehension (MC)
Assembling Objects (AO)
Enlist : How it is Scored
How is the test scored?
You receive a score for each of the eight subtests, as well as a score for three "composite areas" as described below.
Verbal Ability Composite = Word Knowledge Score + Paragraph Comprehension Score
Math Ability Composite = Arithmetic Reasoning Score + Mathematics Knowledge Score
Academic Ability Composite = Verbal Ability Composite + Math Ability Composite
ASVAB Secrets Study Guide
Your Raw Score is calculated with the following formula:
(Word Knowledge Score x 2) + (Paragraph Comprehension Score x 2) + (Arithmetic Reasoning Score) + (Mathematics Knowledge Sore) = Raw Score
So for example, if you score 20 on Word Knowledge, 10 on Paragraph Comprehension, 20 on Arithmetic Reasoning, and 20 Mathematics Knowledge, your raw score would be 100.
The raw score you obtained is also calculated as a Percentile Score. For example, if you scored in the 60th percentile then 40% of the candidates that were tested scored higher than you and 59% had scores that were lower than yours. This score is very important to a recruiter.
The last calculation derived from your scores is the Military Careers Score. This score is a combination of Academic Ability Composite score and the Mechanical Comprehension and Electronics Information scores. The score range is 140 to 240 with 200 being about average. A book titled Military Careers will accompany your test results. It is designed to describe most of the careers available in the military as well as the job requirements for each career. In addition you can reference a graph that shows your chance of acceptance based on the Military Careers Score.
The scores you obtained in the General Science and Auto and Shop Information subtests are not used to calculate any of the above mentioned scores. These scores are used by recruiters to identify other career areas in which you might be successful.
Your first priority should be to get as high a percentile score as you possibly can.
The term "MOS" (Military Occupational Specialty) is used to identify careers in the Army. When reviewing a potential recruit, the Army will divide your ASVAB subtest score into groups that are called line scores. The ASVAB subtests are:
General Science (GS);
Arithmetic Reasoning (AR);
Word Knowledge (WK);
Paragraph Comprehension (PC);
Numerical Operations (NO);
Coding Speed (CS);
Auto and Shop Information (AS);
Mathematics Knowledge (MK);
Mechanical Comprehension (MC);
Electronics Information (EI);
and Sum of Word Knowledge and Paragraph Comprehension (VE).
Note that as Numerical Operations (NO) and Coding Speed (CS) subtests are phased out, some line scores may be changed.
Army Line Scores:
CL - Clerical: VE+AR+MK
CO - Combat: AR+CS+AS+MC
EL - Electronics: GS+AR+MK+EI
FA - Field Artillery: AR+CS+MK+MC
GM - General Maintenance: GS+AS+MK+EI
GT - General Technical: VE+AR
MM - Mechanical Maintenance: NO+AS+MC+EI
OF - Operators and Food: VE+NO+AS+MC
SC - Surveillance and Communications: VE+AR+AS+MC
ST - Skilled Technical: GS+VE+MK+MC
