Originally Posted by Shmens
odometer will read faster? what exactly does that mean?
Your speedometer will say you're going 60mph when your actual speed is closer to 50mph. Your speedo is run off the tranny, not the rpm of the wheel.
Think of it like this:
On a bicycle the speed is read off of the rotation of the wheel, so no matter how you fudge with the gears the speedo will tell you the (relatively) accurate speed.
On a motorcycle the speedo goes by the speed of the rotational speed at the first sprocket. Adjusting the size of the 2 sprockets will influence your speed and force put to the ground.
A good read here
http://auto.howstuffworks.com/speedometer2.htm
