While your behavior after the red light could have resulted in additional problems, especially since a chopper became involved, I think you can still fight the red light ticket.
I am assuming your citation is for CVC 21453...if this is the case, you simply need to prove in court that the officer could not meet the criteria for the citation, as he was unable to view the "limit line." As you said, the officer was the second vehicle from the front when you went through the light, so not only could he not see your red light, he could also not view the "limit line."
Plead not guilty and then in court, spend your time cross-examining the officer to get him to state that he was the second vehicle, that he couldn't see your light, that he couldn't see the limit line (use pictures from his viewpoint, if possible), and then ask for a dismissal based on these issues, as his testimony is insufficient to warrant a finding under the statute he used for citing you. CVC 21453 specificall states that:
"A driver facing a steady circular red signal alone shall stop at a marked limit line, but if none, before entering the crosswalk on the near side of the intersection or, if none, then before entering the intersection, and shall remain stopped until an indication to proceed is shown..."
The biggest issue here is that your cross-examination skills need to be good enough to get the officer to provide information proving that he had no ability to meet the criteria noted above. Good luck...
Edit:
I guess I should have read MXRacer's reply, as he already stated what I have said above...I agree with his post
