ATV.comATV.com - Write Your Review and Win!SportbikeTrackGearCheapCycleParts.comSuperbikeToyStore.comMotorcycle.comMotorcycle.com Classifieds!BikeBanditSpringfield Armory
Motorcycle.com
Old 05-11-2006, 02:17 AM   #1 (permalink)
redR62004's Avatar
redR62004's Garage
Default tire wear
It seems that I go thought my back tire faster then my front?People that I have talked to say the front should go first then the back?Does the suspention have anything to do with tire wear?I roll on the gas in the turn most of the time could that make the front light and make for less wear on it?One other thing I have to bye new shoes all time,when lean the bike good my toes hit the gound,Ive never tried to put the knee out.Is my foot postion wrong?
redR62004 is offline   Reply With Quote
Old 05-11-2006, 02:47 AM   #2 (permalink)
JAOOREEAARB!!
AwwsChwA's Avatar
AwwsChwA's Garage
As for your tires, I've always seen, and had, the rear tire wear first. I really don't know for sure why, but my theory is that it's the same as on a car, the driving wheel(s) wear first.
Suspension has a lot to do with tire wear, the suspension controls how hard the tires push back against the ground when you hit bumps, controlling how much the tire is scrubbed off. And yes, it is possible that, since you roll on the throttle in a turn, you're making the nose a little lighter. Also keep in mind that, when you roll on the throttle in a lean like that, you're causing just a tiny amount of slip in the rear tire. Not much, it's not like you're fish-tailing, but the rear tire is spinnign just a tiny bit against the pavement, causing more of the rubber to scrub off.
One other thing I noticed in my own riding, my tires wear a crapload faster when they're hot. When I've been tearin up twisty roads for an hour or so, my tires will get really hot and start to just peel away. That, combined with how you roll on the throttle, could also explain why the rear wears faster.
As for your toes hitting the ground, that will happen unless you adjust your posture to stick the knees out. I've had that happen before too, i took a big chunk off the toe guard on my right boot becuz I wasn't postured properly and my toe dug into the ground on a hard right-hander. Find a safe road to practice knee-drag posture, that'll help preserve your shoes.
Originally Posted by riggz
its not really physics, more like anatomy. but dragging a knee makes your balls increase in size thus adding a little more weight on the lean side of the bike.
Originally Posted by Yamaha R6
Can we please start WW3 already i am sick of this shit.
AwwsChwA is offline   Reply With Quote
Old 05-11-2006, 03:43 AM   #3 (permalink)
RideOrDie's Avatar
RideOrDie's Garage
When your toes hit, are you riding with your arch of your foot on the pegs or are they on the ball of your foot.
The correct position is that you should be riding with the ball of your foot on the pegs. Only dropping them down to shift. Other than that, they stay up.
RideOrDie is offline   Reply With Quote
Old 05-11-2006, 11:42 AM   #4 (permalink)
redR62004's Avatar
redR62004's Garage
thanks guys i'll try with the balls of my feet.One last thing dont know if anybody can help with this one in this spot but do I need to change my springs in the front to get the best suspention setup for my wieght?
Old 05-11-2006, 02:02 PM   #5 (permalink)
JAOOREEAARB!!
AwwsChwA's Avatar
AwwsChwA's Garage
We can't answer that until we know how much you weigh.
Old 05-11-2006, 02:08 PM   #6 (permalink)
redR62004's Avatar
redR62004's Garage
opps I forgot that part with gear about 155lbs.Iam taking it to race shop on monday for them to set it.From what I have read on here is stock is for about 170.
Old 05-11-2006, 02:59 PM   #7 (permalink)
Two Wheel Addict
Deltfather's Avatar
Deltfather's Garage
everything I have heard says that stock suspension is best for the flyweights like yourself.
"What are they going to do ... arrest us for being awesome?"
Deltfather is offline   Reply With Quote
Old 05-11-2006, 04:01 PM   #8 (permalink)
JAOOREEAARB!!
AwwsChwA's Avatar
AwwsChwA's Garage
haha...flyweight, awesome. I weigh 170, the stock suspension does just fine for me, I think your weight will be fine too.
Old 05-11-2006, 10:04 PM   #9 (permalink)
Rsiccness's Avatar
Rsiccness's Garage
How is your corner speed coming into a turn? I use to go through 2 rears for every front on the street. I was riding up in the canyons but was not very fast at the time. Than I discover entry speed thanks to Codes book on practicing "the no braking technique." My tires started wearing out pretty evenly, but the rear is still the first to go. I currently don't ride as aggressively in the canyons as I use to, so the rear is wearing out faster than the front.
Rsiccness is offline   Reply With Quote
Old 05-11-2006, 11:20 PM   #10 (permalink)
Party Life
Inten_Z's Avatar
Inten_Z's Garage
I have problems dragging my toes too.
http://www.photoreflect.com/scripts/...um=0&adjust=-1
Most people will wear the rear faster than the front..
Several
Inten_Z is offline   Reply With Quote
