Sequential gearbox...no need to use a clutch when coming up through the gears...especially under heavy acceleration...just a slight roll off the throttle...then upshift. If done properly, timing is critical, you will see why you want to shift with no clutch
03 R6, Limited Edition Black with Red Flames, Micron High Mount Fusion Black/Red Exhaust, PCIII with USB, Factory Pro +4 Ignition Advancer, BMC Race Filter, Factory Pro Superflare Velocity Stacks, Graves Slide Stops, 520 RK Chain Conversion (-1 Fr +2 Re), LP flushmounts, Clear Alternatives Integrated Tail Light, Fender Eliminator, Puig Dark Smoke Racing Screen, Protek Frame and Clutch Sliders, ProGrip Tank and Gas Cap Pad, Yamaha Half Tank Cover
