McCoyMotorsportsMotorcycle.comMotorcycle.com Classifieds! BikeBanditATV.com - Write Your Review and Win!SportbikeTrackGear
Go Back   R6Messagenet.com > Yamaha YZF-R6 > R6 Warranty and PreMature Failure
GoFreeCreditReport
Old 09-15-2006, 02:48 PM   #21 (permalink)
Azr6's Garage
Trader Rating: (6)
Originally Posted by forumsearcher
I purchsed my bike with the 2nd gear problem... It cost me $100 to fix my 2nd gear, and a day of work... I would rather fix the gears a few times than go and spend $1300. Hopefully I am a better shifter than the first owner.
Howd you fix it for so cheap?
Azr6 is offline   Reply With Quote
Old 09-16-2006, 12:52 PM   #22 (permalink)
Johns02R6's Garage
Ok I just checked back here and I can't believe the response it got. Everybody knows that the newer tranny is better (03-05). The extra dog and the bigger shift fork (for 2nd gear) really do make a big difference in wear resistance and strength. I wouldn't make the swap unless the bike was already jumping out of gear though.
Thrak is not correct regarding when the problem occurs. Obviously poor shifts will make it fail prematurely, but the dogs and windows will simply wear over time even with perfect shifts due to the nature of the design. So just because the tranny works fine now, that doesn't mean it won't start slipping tommorrow. It's obvious that not all the 99-02 R6's have had the problem yet, which makes some people think that since they haven't had the problem yet, everyone else must just be an idiot. Give it time and it will fail. The harder you beat it, and the more you use it, the sooner it will fail. Riding 24K track miles doesn't mean crap because you aren't shifting from 1st to 2nd out on the track. 24K miles of stop-and-go in town abuse is MUCH different. So don't let mileage numbers fool you.
I just posted this to help people fix the problem once their bike fails. Our local sprint car shop up the street has R6 motors putting down 120+rwhp on alcohol. He is using STOCK 03-05 trannys (1st and 2nd gear only), and has never had a problem with them failing. He doesn't even undercut them. He did tell me that he doesn't like to use the earlier trannys because even with an airshifter (for perfect shifts) on the karts, the 2nd gear fails rather quickly. Undercutting does help, but he still prefers to use the newer parts.
PS: to fix your own tranny for $100, take it apart yourself, take 2nd gear wheel and 6th gear pinion to a machine shop and have them undercut at 5 degrees. Then reinstall the parts yourself and enjoy your tranny that doesn't jump out of 2nd. It won't be near as smooth or able to handle as much power as the newer trans, but at least it will work.
Johns02R6 is offline   Reply With Quote
Old 09-16-2006, 02:03 PM   #23 (permalink)
Loves ( . Y . )
blackonwhite99r6's Avatar
blackonwhite99r6's Garage
Trader Rating: (19)
how much does is the raw parts cost of an 03 tranny with self installation?
blackonwhite99r6 is offline   Reply With Quote
Old 09-16-2006, 02:32 PM   #24 (permalink)
Rob Sherman's Avatar
Rob Sherman's Garage
http://www.mrcycles.com/
Installation would depend on who you have do it... $1000??
'99 R6
Rob Sherman is offline   Reply With Quote
Old 09-16-2006, 02:52 PM   #25 (permalink)
Loves ( . Y . )
Trader Rating: (19)
803 dollars for all the parts on the 03 tranmission fiche from mrcycles. If they transmissions are compatible could you just use the 03 gears with other 02 parts?
Old 09-16-2006, 06:38 PM   #26 (permalink)
Rory's Garage
What is GP shift style and how does it help shift smoother? I've reamed out first gear and shifted to second and there was grinding in the shift, but I never understood what I did wrong to cause this. Where is there technique in shifting (excluding feathering out the clutch) it's as simple as go - pull clutch - click shifter - feather clutch out. Where did I go wrong?
Rory is offline   Reply With Quote
Old 09-16-2006, 08:22 PM   #27 (permalink)
Loves ( . Y . )
Trader Rating: (19)
With a quick revving engine like the 600s in all motorcycles the rpms drop very quickly. If you are moving and you are trying to click it into 2nd gear it will click in harder if the rpms arent close to matched with your speed. In other words, shift before the engine rpms drop down and you wont have as much of a problem. so it should be like, braaaaaaaaaaa-shift-braaaaaaaaaaa not braaaaaaa-aaaa-shift-braaaa...get what Im saying?
Old 09-16-2006, 09:09 PM   #28 (permalink)
Rory's Garage
perfectly clear, thanks
Old 09-16-2006, 10:33 PM   #29 (permalink)
Thrak's Garage
Trader Rating: (7)
whatever dude... I've had 4 99-02 R6s.
1 99
1 01
2 02's
the 02s were street only, and had TONS of miles... stop-and-go Atlanta traffic miles. I've never had a 2nd gear problem. Period.
You mis-shift, or try to jam it, and you're gonna get the problem. If its a desing flaw, as you say, every 99-02 R6 would have the problem, and they dont.
Thrak is offline   Reply With Quote
Old 09-17-2006, 03:24 AM   #30 (permalink)
jlsparky7's Avatar
jlsparky7's Garage
Can you use the 03 gears on the 02 tranny?
jlsparky7 is offline   Reply With Quote
Harley Davidson Suzuki GSXR Ducati Forum Kawasaki Forum Sportbikes Forum
V-Rod Forum GSXR Forum Ducati Monster Vulcan Forums Triumph Forum
Harley Forum Suzuki SV Honda 600RR Kawasaki ZX Forum Triumph 675
Buell Forum Yamaha R1 Honda 1000RR Kawasaki ZX-10R Can Am Spyder
KTM Forum Yamaha R6 Honda Fury Forums Kawasaki KLR 650 Aprilia Forum
Victory Forums YZF-R6 Forum Honda Goldwing Kawasaki Versys BMW S1000RR Forum
