01 R6 Idle Speed Keeps Changing? Help
Got a quick question.
Whenever I start my bike up after it has been sitting for a while I need to adjust the idle knob to make it idle higher or it won't stay running, that or leave the choke on. But when the bike finally warms up the idle goes really high and I need to the adjust the idle knob back down or the bike sits at a high RPM with no one touching the throttle. This happens at stop lights too. Say I come to a stop at a stop light, my bike will obviously go down in RPMs but after sitting at the light for about 5 seconds the idle will go way up and sometimes I hvae to adjust the idle at the stop light.... what is the issue? Should I just run a bunch of sea-foam through it or is it something that really should be fixed?? Thanks for any info
