SuperbikeToyStore.comSportbikeTrackGearMotorcycle.com Classifieds!BikeBanditCheapCycleParts.comMotorcycle.comCycleGear.comRacerPartsWholesaleHardRacing.comATV.com
Old 08-20-2008, 09:15 AM   #1 (permalink)
NCM213's Garage
Default Cloudy Oil r6 06
Bike has been sitting for awhile. rode and then checked oil. CLOUDY OIL. What are possible problems?
NCM213 is offline   Reply With Quote
Old 08-20-2008, 01:30 PM   #2 (permalink)
Achapman > Jimbo > Stunaz
achapman's Avatar
achapman's Garage
Moisture and crap accumulating. How long was it sitting?
Change the oil and filter asap.
R6S--Devil Shotgun--Dark Smoke Puig DB--4300K Hids--Saefirebird conversion--Cleggs Angel eyes--All around Intuitive sliders
achapman is offline   Reply With Quote
Old 08-20-2008, 02:06 PM   #3 (permalink)
NCM213's Garage
Are these the syptoms of a blown head gasket. I changed the oil and could actually see green coolant beads as I the oil drained. Is this the sign of a blown gasket, cracked block, water pump seal???? Motor runs great but has collant issue. Thanks for the help. Hope I can fix without paying $$$$$$$
Old 08-20-2008, 02:31 PM   #4 (permalink)
"Ride Hard but safe"!!!
R6 Raven's Avatar
R6 Raven's Garage
well if you buy the parts and do it your self then you wont spend that much... but to figure out the source of the problem thats the hardest part.. it could be some where around the head gasket or some where around the cooling line in the engine itself... hopefully its just a head gaket issue... if engine crack is the source then go to e-bay.
R6 Raven is offline   Reply With Quote
Old 08-20-2008, 05:57 PM   #5 (permalink)
NCM213's Garage
what causes a blown headgasket? Build up in pressure? any visible sign from the exterior part of the motor?
Old 08-21-2008, 06:00 PM   #6 (permalink)
NCM213's Garage
In order to replace the head gasket. Do I need to drop the engine? Or is it possible to go through the top? Thanks
Old 08-21-2008, 06:35 PM   #7 (permalink)
wish I had a honda
epiphone3's Avatar
epiphone3's Garage
sometimes a build up in pressure can do it... but what causes the build up in pressure? Check your crank case breather to see if it is kinked or blocked off in any way. This can cause a build up in crank case pressure which can show up in multiple ways.
there are other ways the head gasket can go... maybe just a defective or incorrect install from the factory, etc.
2005 Raven with PUIG light smoke racing screen, Watsen Designs R1 Front LED Blinkers, Watsen Rear LED mini Blinkers, Watsen Fender Eliminator, Watsen internal plate light kit, Pitbull red anodized Spools
epiphone3 is offline   Reply With Quote
Old 08-21-2008, 06:39 PM   #8 (permalink)
wish I had a honda
epiphone3's Avatar
epiphone3's Garage
I would pull the motor, put it on a good stand that allows you to turn it every which way. Trying to screw around with it inside the bike maybe a bigger pain the arse than its worth... I don't even know if there is room to pull the head out of there from the top any way!
Also, get a good torque wrench. I highly recommend Snap-On ones with the thumb wheel on the side (not the spring loaded handle) or a Snap-On electric torque wrench. Expensive, but will make the re-assembly go much better. Snap-on even makes an electronic torque wrench with a built-in degree function for fasteners that require a torque + angle... examples of such fasteners are head studs, cam bearings, main bearings, and connecting rod bearings.
Old 08-21-2008, 09:55 PM   #9 (permalink)
NCM213's Garage
When I have the engine removed. Does the very top gasket have a role in channeling the coolant or does this gasket just keep oil in? (Cylinder head cover gasket) Could it also be possible the Cylinder head gasket is damaged? Are both of these gaskets involved in seperating coolant from oil?
