AdvanstarMotorcycleShowsMcCoyMotorsports
Allstate
JardineProducts.comMotorcycle.comSportbikeTrackGearMotorcycle.com Classifieds!
GoFreeCreditReport
Old 06-08-2008, 12:10 PM   #1 (permalink)
david240968's Garage
Default Gear probs....any advice please
i have a 2000 r6 and all has been fine until today. normally when i stop and pop it into neutral i can feel it click into place. today when i stopped there was no click and it felt as if there was no resistance when i change to either first or second. when idling it can put itself into first and stall or go from first to neutral without any input from me.
any help as to what is wrong or how to fix it would be greatly appeciated.
david240968 is offline   Reply With Quote
Old 06-08-2008, 01:08 PM   #2 (permalink)
natedogg624's Avatar
natedogg624's Garage
might want to check the detent spring or the shift shaft assembly. i had the exact same problems you are describing.
odd gear changes without my knowledge, hard to shift out of neutral, or couldn't change out of a gear at all.
open up the shift shaft cover and look in there. its the thing right above front sprocket cover. it could either be the detent spring (.80 cents) or the shift shaft assembly (~40.00)
natedogg624 is offline   Reply With Quote
Old 06-08-2008, 01:28 PM   #3 (permalink)
can you let me know what i would be looking for and if i remove that cover will oil come out??
Old 06-08-2008, 02:38 PM   #4 (permalink)
here (some pics are copied from the detent spring how to)
this is what it looks like with the cover off.
and for me it was the shift shaft assembly that chipped (when i pulled the cover off, the shift shaft assembly came with it--so you see the shaft and cover together in the following two pics).
whichever it may be, the source of your problem will be lying at the bottom of the casing. if there isn't a spring, or metal chip in the bottom, pull the shaft out (just literally grab the shaft and pull...very easy) and check that nothing spins freely meaning it will move but will stop either by the spring or the stopper or both. there are two main components on the shift shaft assembly, one of them is a long spring from the shaft that will be there and the other is on the lower right part of the assembly, and that is a component that should not be able to spin freely. meaning it should have resistance from both the spring tensioner and also a stopper.
for instance, mine should not be able to move this far
and no when you open it up, there will be a drip or two of oil in there no more, nothing will spill out all over the place. also the hardest part was getting the cover off. there are three little places where you can get your "fingers" in there to pull it off. this was very hard for me and i ended up getting a long allen "L" wrench and using it as leverage to pry it off.
link to detent spring how to
good luck!
Old 06-08-2008, 05:05 PM   #5 (permalink)
many thanks for your help. took it all apart and found the spring had broken. managed to do a temporary fix until i can get a new spring.
Old 06-08-2008, 08:51 PM   #6 (permalink)
lucky you
i changed my spring while i was in there anyways.
