HardRacing.comBikeBanditCycleGear.comAdvanstarMotorcycleShowsSportbikeTrackGearMotorcycle.comATV.comRacerPartsWholesaleSpringfield Armory
Motorcycle.com
Old 05-18-2006, 07:42 PM   #1 (permalink)
Phi Alpha
saefirebird's Avatar
saefirebird's Garage
Trader Rating: (32)
Default How-to: 06 R6 GP Shift
1. Remove Mid Fairing (4 allen fairing bolts and one pop rivet).
2. Remove bolt from shifter arm using a 10mm wrench. (Note that dot on shifter arm lines up with central line going across shift shaft).
3. Unbolt shifter from kickstand using 8 mm allen wrench.
4. Rotate shifter arm so it is now on the opposite side of the shift shaft (line up dot with line going across shift shaft).
5. Reinstall bolt in shifter arm and tighten using 10mm wrench.
6. Reinstall bolt into kickstand (also apply blue loctite) using allen wrench.
7. Reinstall Mid Fairing (4 allen fairing bolts and one pop rivet).
You have thus successfully converted your 06 R6 from standard shift pattern (1 down, 5 up) to a GP shift pattern (1 up, 5 down).
Difficulty: EASY
Time involved: 10-15 minutes
Tools needed: 10 mm wrench and allen wrench (8 mm and 4.5 mm), Blue Loctite
Bikeless.
saefirebird is offline   Reply With Quote
Old 05-18-2006, 07:54 PM   #2 (permalink)
#69
aar0ncee's Avatar
aar0ncee's Garage
Trader Rating: (6)
whats gay is, i had to pay 400+ to be able to do that with my R1
r1messagenet.com - life with a twist
Originally Posted by tetsuo
aaronce gets his skillz from me. he's a squid. dont follow after him.
aar0ncee is offline   Reply With Quote
Old 05-18-2006, 08:04 PM   #3 (permalink)
Phi Alpha
Trader Rating: (32)
It is my understanding that you can leave the bolt in the kickstand and just swap the shift arm around to the opposite side....but I chose to unbolt it. FYI.
Bikeless.
Old 05-18-2006, 08:21 PM   #4 (permalink)
GUINNESS®
STi-R6's Avatar
STi-R6's Garage
pretty cool , but i think ill leave it how it is.
2008 Toyota Trail Teams FJ Cruiser
2006 R6
"Therefor the grace of God go I"
STi-R6 is offline   Reply With Quote
Old 05-18-2006, 08:58 PM   #5 (permalink)
Hi , How are ya
6sN7s's Avatar
6sN7s's Garage
Trader Rating: (7)
Just another noe you may want to make. On the bolt buy the end of the mid fairing you should put a small spacer to keep the platics from hitting the rod.
You All Laugh Because I Am Different, I Laugh Because You're All The Same.
6sN7s is offline   Reply With Quote
Old 05-18-2006, 09:02 PM   #6 (permalink)
Phi Alpha
Trader Rating: (32)
On mine, the foam padding is right there and keeps it from coming close to the mid.
I'll keep an eye on it though.
Bikeless.
Old 05-22-2006, 05:18 PM   #7 (permalink)
Ryloth's Avatar
Ryloth's Garage
Just out of curiousity, why would one do this? Any advantages?
Ryloth is offline   Reply With Quote
Old 05-22-2006, 06:01 PM   #8 (permalink)
2006 Anniversary Edition
R6Rocket718's Garage
Personal preference. Some like to be able to push down to upshift, especially while leaning the bike over...
-Could it be they fear the pain of death, or is it they fear the joy of life?-
R6Rocket718 is offline   Reply With Quote
Old 05-23-2006, 03:09 AM   #9 (permalink)
BORN TO RAISE HELL
tuscanijon's Garage
I am very use to the GP shift, on my 05 R6 I had it for a while and I just got the 06 R6 no more then a few days ago, and I get kinda confused if I don't think about it. I am going to convert this one to GP for sure. But again its just personal prefference. Although stomping down through the gears it is less likely to miss shift.
tuscanijon is offline   Reply With Quote
Old 05-23-2006, 05:59 AM   #10 (permalink)
Got Speed?
Demon46's Garage
Kickass post, dude! I've been interested in trying out the GP-style shift pattern, but I didn't realize it was that easy to make the change.
I'll definitely be giving this a try soon. Thanks for the how-to!!
Demon46 is offline   Reply With Quote
