Motorcycle.com ATV.com - Write Your Review and Win!McCoyMotorsportsBikeBanditSportbikeTrackGearMotorcycle.com Classifieds!
Penn Foster
Old 10-06-2004, 04:47 PM   #1 (permalink)
Self Proclaimed Genius
ochlocracy's Avatar
ochlocracy's Garage
Trader Rating: (10)
Default How-to: Adjust your forks for a 70 series tire.
This one is pretty simple. It will take you about 30 min tops. I am going to explain how to adjust the front forks to compensate for the larger tire up front, thus keeping the bikes geometry.
You may also need to adjust your front fender, as the tire heats up it will balloon up and scrape the front fender possibly damaging it. On my ’99 I had to move it up (after I damaged it, cause my shop put the 70 without telling me) On my ’04 I took the same chance driving home on the 70 not trying to heat it up too much. I got home without damage and then actually didn’t bother to adjust it and took it out for 6 hours the next day aggressive riding without any damage. You choose.
You will need
4mm hex
5mm hex
6mm hex
Measuring tool
Small jack
An extra set of hands.
Start off by removing your clip-ons there are 4 bolts all together, two of them are located underneath the black plastic covers.
Then remove the 1 blot holding your brake fluid reservoir to you triple tree
Now you should be able to remove you clip-ons by pulling them up over the top of your forks.
Now with your clip-ons off you need to take a measurement. Measure from the top of the upper triple tree to the top edge of the fork tube. You only need to measure one side, they should both be the same anyway. Now add about 8mm to the measurement you just found. This is how high the forks tubes should be when we are done.
Next use a small car jack and place it under your headers and jack you bike up; the jack, your side stand, and the rear tire will support the bike.
Here is a pic provided by AFC (rear stand and wood not required)
Once the front tire is off the ground you need to loosen the lower triple tree bolts, they're 2 for each tube. (located behind my cables in the photo)
Now this is where you might need an extra set of hands to help stabilize the bike and loosen the upper triple tree. Stand in-front of the bike and hold the front tire, it is going to fall through the triple trees if you don’t. Now loosen the upper triple tree.
With the upper triple tree bolts loose push the fork tubes up and measure, once you have them in position tighten the upper triple tree bolts and then re-check the measurement. If they are within spec. then tighten the lower triple tree and put back on the clip-ons.
Now, to add a few more things to this how-to. First off this is what happens when you don’t adjust your front fender on a 1st generation R6.
Second in the how-to I said to adjust to about 8mm higher, this can be different depending on what brand tire you bought, how much tread you have on it, and just how you think the bike feels. I first adjusted my forks to 10mm higher, and then noticed my front end sort of tucking in the corners so I brought them back down to 8mm and they seem great now. This is on my ’04.
On my ’99 I didn’t adjust the forks at all, the bike felt so much for solid with just putting the 70 on there.
© Copyright 2005 - R6Messagenet.com - All rights reserved.
ochlocracy is offline   Reply With Quote
Old 10-07-2004, 02:59 PM   #2 (permalink)
Rendezvous With Destiny
RajunCajun's Avatar
RajunCajun's Garage
Great write up
I assume this would be same effect before/after on a 03 R6.
Keep up the good work
2003 Black N Red R1
2003 Black N Red R6 Track Bike (soon)
2001 SVT Cobra (Highly Modified)
Invisible Souls Leave .308 Holes
RajunCajun is offline   Reply With Quote
Old 10-07-2004, 04:20 PM   #3 (permalink)
sportbiker's Avatar
sportbiker's Garage
Nice write up ..
sportbiker is offline   Reply With Quote
Old 10-08-2004, 05:54 PM   #4 (permalink)
madchild's Garage
if your jacking up your bike with a car stand...wouldn't it put a dent in it?
Jason Cheng
CHENG DYNASTY RACING
CRA #223
2006 Yamaha R6
2009 Sponsors:
Cheng's Dynasty, Lithium Motorsports, Bobby and Steve's Auto World, Studio299, Motoprimo, Armour Bodies, Woodcraft, Scorpion, Ridingcourse.com, Pirelli
madchild is offline   Reply With Quote
Old 10-08-2004, 08:27 PM   #5 (permalink)
ochlocracy's Avatar
ochlocracy's Garage
Trader Rating: (10)
No
Old 10-08-2004, 09:52 PM   #6 (permalink)
AFC
Stonecutter
AFC's Avatar
AFC's Garage
Trader Rating: (21)
As ochlocracy said:
Like it says in the how-to, most of the weight of the 400 LB R6 is still supported by the rear tire and the sidestand using this method.
AFC is offline   Reply With Quote
Old 10-12-2004, 05:39 AM   #7 (permalink)
Habitual Linestepper
Cesario's Avatar
Cesario's Garage
Default re:
thanks again och, you're a life saver.
myspace.com/cesario
Cesario is offline   Reply With Quote
Old 10-12-2004, 04:20 PM   #8 (permalink)
RC51 Traitor
Shrewd's Avatar
Shrewd's Garage
Thanks! I appreciate all your how-to's!
It's funny how the bikes with the most mods are usually the slowest riders
"Your chicken strips sure go well with that new exhaust"
Shrewd is offline   Reply With Quote
Old 10-12-2004, 04:35 PM   #9 (permalink)
#1 member
serpentracer's Garage
nice ochlocracy, One thing I read someplace is how to know how much to lower.
the article said to measure both tires diameter using a string or one of those tape measures tailors use. use the difference in the two measurements for the amount to raise the forks.
serpentracer is offline   Reply With Quote
Old 10-12-2004, 04:49 PM   #10 (permalink)
ochlocracy's Avatar
ochlocracy's Garage
Trader Rating: (10)
Yea that is on the sport rider site. I thought about including it but they ask you to check you old dia. and your new dia. Well most of us would have already replaced the old tire. Also since we all have the same bike, it will be the same for everyone.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Harley Davidson Suzuki GSXR Ducati Forum Kawasaki Forum Sportbikes Forum
V-Rod Forum GSXR Forum Ducati Monster Vulcan Forums Triumph Forum
Harley Forum Suzuki SV Honda 600RR Kawasaki ZX Forum Triumph 675
Buell Forum Yamaha R1 Honda 1000RR Kawasaki ZX-10R Can Am Spyder
KTM Forum Yamaha R6 Honda Fury Forums Kawasaki KLR 650 Aprilia Forum
Victory Forums YZF-R6 Forum Honda Goldwing Kawasaki Versys BMW S1000RR Forum
