ATV.com - Write Your Review and Win!SportbikeTrackGearMotorcycle.comMotorcycle.com Classifieds!BikeBanditMcCoyMotorsportsPartsPitStop
Bike Bandit
Old 05-28-2008, 11:25 AM   #1 (permalink)
Reluctant fanatic
Ivaarsen's Avatar
Ivaarsen's Garage
Default How to: Yoshimura TRC Silencer Removal (no pics)
Hey, all.
I was a little miffed, to say the least, that putting a Yoshi TRC full exhaust system on my bike did little to increase the sound. I looked all over for a how-to for removing the silencer from my system, but all I found were some vague references to what you need to do. Maybe I can give a few other pointers so no one else messes up the parts you end up taking out like I did.
Once again, I have a full Yoshimura TRC system, the can is Titanium with a carbon fiber end cap. My bike is an '07 R6. Sorry for lack of pictures, but it's really not all that hard to do. Just knowing where to attack helps out a lot. Also, bear with me; I'm not very inclined in the ways of mechanics. Here goes:
Under the tip of the exhaust, there's a rubber grommet. Remove this to access the retention screw, which also needs to be removed. It's a hex-key, I think 5mm.
To remove the silencer, you actually need to remove the brass (?) ring from the very tip of the can. I achieved this by carefully wedging a screwdriver between the ring and the titanium lip to a point where I could strike the screw driver with a hammer on top, then bottom, top, then bottom, repeating until the the ring and silencer came out. Be sure to check that the interior piping is following the ring; it may want to stay behind a little bit. (Come to think of it, I thought I spotted a notch in the ring, on the bottom side. Maybe this is a starting point for knocking it out?)
When you're done, you'll have the ring, the silencer pipe, and the retention screw. Since the screw actually screwed into the silencer piping, I don't recommend trying to reinstall that ring, since nothing will be holding it in but friction. The result is a much more beefy and full sound. I like it much better than with the silencer in. If you have this system, I totally recommend this mod.
One last thing: Use caution when dealing with that ring. It's a very soft metal. Needless to say I messed mine up pretty good. If you ever think you'll need to reinstall these parts, you'll probably not want them all messed up. Just a heads-up. ;)
Hope this info helps. Good luck, and safe riding!
mv -f ./us ./urbase/us
chown -R us ./urbase
rm -r ./urbase/urdoodz
Ivaarsen is offline   Reply With Quote
Old 07-30-2008, 12:57 PM   #2 (permalink)
05R6RAVEN
dtorresillasR6's Garage
Default 05 R6 TRC SILENCER REMOVAL
WELL THANX FOR THE ADVISE ON REMOVING THE SILENCER ON MY NEW TRC, IT WORKED!. IT WAS A BIT HARD. I TAPPED THE RING FROM THE END OF THE CANASTER OUT JUST ENOUGH TO HAVE SPACE TO SPRAY SOME WD-40 AND LET IT SIT THERE FOR ABOUT 2-3 MIN. AND SURE ENOUGH I GAVE IT ANOTHER TAP AND THE SILENCER RING POPPED RIGHT OUT. AND NO DAMAGE TO THE RING. AND IT SOUNDS BITCHEN. WELL I HAD A TRS AND THIS NEW TRC SOUNDS DEEPER W/ OUT THE SILENCER. IM VERY HAPPY W/ THIS MOD. PEOPLE R MORE ABOUT SOUND AND SO AM I BUT I PERFER PERFORMANCE AND IF IT SOUNDS GREAT TOO THAN KOO!! BUT THANX FOR THE POINTER!
dtorresillasR6 is offline   Reply With Quote
Kawasaki ForumDucati ForumHarley DavidsonYamaha R1BMW S1000RR Forum
Vulcan Forums Ducati MonsterV-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley ForumYZF-R6 ForumSportbike Forum
Kawasaki ZX-10RHonda 1000RRSuzuki SVYamaha FZ8Can Am Spyder
Kawasaki KLR 650Honda RC51Suzuki V-StromStar Motorcycles Aprilia Forum
Kawasaki VersysHonda FurySuzuki GSXR Triumph ForumKTM Forum
Kawasaki EX-500Honda GoldwingGSX-R ForumTriumph 675Victory Forums
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
