Originally Posted by stanjohanshen
Is there any post out there with pics on how to run an LED light kit with 20-40 LED's?
Thanks,
I have leds on my bike... its not that hard.... what we did is first started to place the lights where we wanted them.... then after that make sure you can pull the wires to the same location with plenty of wire.....after that combine all you positive and negative wires, by either soldering them or just connecting them together..... then take the positive wires after you have put them together and run that into you switch or whatever you want to turn them on.... from the switch run a wire to a fusebox.... after that take the fuse box wire and connect it to your positive terminal on you battery.... after that take all the negative wires and connect them to your negative terminal.... this is how we ran mine... if you want some pics let me know..... havent had any problems with them and my buddy is a dealer that put them on for me...
