BikeBanditMotorcycle.com Classifieds!SportbikeTrackGearCheapCycleParts.comRacerPartsWholesaleHardRacing.comSuperbikeToyStore.comATV.comAdvanstarMotorcycleShowsSpringfield Armory
CycleGear.com
Old 03-28-2008, 09:38 PM   #1 (permalink)
mehsham's Garage
Default Changing drain bolt at every oil change
I was looking at how to DIY for oil change and notice the writter stresses on the fact that the bolt and washers should be replaced... What i want to know if others do that as well...
Thank you
mehsham is offline   Reply With Quote
Old 03-29-2008, 01:01 AM   #2 (permalink)
natedogg624's Avatar
natedogg624's Garage
i have not heard of replacing the bolt itself but i have heard you should replace the crush washer every change.
but i haven't done that and no problems so far, although next oil change i will replace it.
natedogg624 is offline   Reply With Quote
Old 03-29-2008, 05:35 PM   #3 (permalink)
Adionik's Garage
I didn't change the oil washer and everything is running just fine. I would have but the dealer is hella far...I think that washer is like $.10 cents. Mine looked absolutely perfect before and after changing it.
Adionik is offline   Reply With Quote
Old 03-29-2008, 07:13 PM   #4 (permalink)
rayr6's Garage
It will prevent oil leaks that people tend to solve by over tightening your bolt. The crush washer is 10 cents or less and should be changed every time. Once it's "crushed" into place and you loosen it up it's done for and needs replacement. Although you could get away with never replacing it, it should be done. Stock up if you have to so you always have one around. As for the bolt, that is good for life.
rayr6 is offline   Reply With Quote
Old 04-01-2008, 09:35 PM   #5 (permalink)
I sell them
Druggs's Avatar
Druggs's Garage
hahahahah replacing the bolt...common sense should have answered that one. now the crush washer is another issue all together.
Mass genocide is the most exhausting activity one can engage in…next to soccer.
-Loki
Druggs is offline   Reply With Quote
Old 04-02-2008, 11:17 AM   #6 (permalink)
mehsham's Garage
Thanks for the input guys..
I know common sense would answer many questions .. forgive me for the ignorance but i don't have much knowledge on washers or bolts.. My understanding was as long as the washers are intacked in one piece then itcan be reused but turns out we need to replace it.
About changing the bolts.. i got this off from the How To section pertaining to "oil change?"...
"It is not a bad idea to keep track of the common fasteners and parts that may need replaced later on and order spares to have on hand.
...BE SURE YOU HAVE REPLACED THE DRAIN BOLT !!!"
I've known of instances whenbolts were over torqued(tightened more than what they are supposed to) and eventually in due time it broke because of shear fracture over the period of time..
None the less thanks again for the input guys ...
Old 04-02-2008, 11:48 AM   #7 (permalink)
h to the izzo
cashmoneyflo's Avatar
cashmoneyflo's Garage
Trader Rating: (5)
i change my bolt every once in awhile, but definetly not every oil change, thats unnecesary. good idea to change crush washer every change but i do it if i remember to ask for one when i go to get oil
cashmoneyflo is offline   Reply With Quote
Old 04-07-2008, 12:11 AM   #8 (permalink)
Jay2's Avatar
Jay2's Garage
I have never changed the washer or bolt for that matter on any of the bikes I've had and have never had a problem. I can understand replacing the washer from time to time but everytime is unneccessary IMO.
Racefit | Carrozzeria | Michelin | Galfer | Rizoma | Driven | RK | Pazzo | GYT-R | Greggs | Clear Alternatives | HealTech | Motul | HID
Jay2 is offline   Reply With Quote
Old 04-08-2008, 08:32 PM   #9 (permalink)
stanjohanshen's Garage
Default Stripping
you don't want to strip or dent your oil pan either. The washer will prevent this.
stanjohanshen is offline   Reply With Quote
Old 04-08-2008, 09:12 PM   #10 (permalink)
Big Deezul's Avatar
Big Deezul's Garage
Trader Rating: (34)
I changed my oil after every race weekend...same bolt, same washer...no leaks or pan stripping
Big Deezul is online now   Reply With Quote
