HardRacing.comSportbikeTrackGearAdaptiv Technologies LLCATV.comCycleGear.comRacerPartsWholesaleCheapCycleParts.comMotorcycle.com Classifieds!Motorcycle.comSpringfield Armory
Old 02-20-2008, 12:42 AM   #1 (permalink)
bugsysiegals's Garage
Question European Lefthand Switch on American 2004 R6
I own a 2004 R6 and I just bought the European left hand switch which has the hazard button and flash to pass trigger. From what I understand, the European model is the only model to come with these 2 features.
I thought it would be a good idea to put it on my bike to have the extra features and also so that I would have easy access to a trigger mod which is hooked up to my garage door opener and a hazard button which will be wired up to some other mod (LED's, radar jammer, tail light cutoff, etc).
It is also my understanding that the hazard switch will work just buy plugging in the harness but the flash to pass will not. I've only seen one other post where somebody claimed you had to splice a wire in order to make it work; however, the person never left the instructions behind and only stated that he could give the instructions if somebody wanted to know!! I've tried to contact him and I haven't received any response thusfar.
If anybody knows anybody who has installed a European lefthand switch on their bike or has done this themselves, please share with everybody how to get the flash-to-pass trigger to work. What has to be done or which wires need to be spliced in order to make this feature work?
I would greatly appreciate any advice on this before I try start hacking up the wires with what I think needs to be done.
bugsysiegals is offline   Reply With Quote
Old 02-21-2008, 11:34 AM   #2 (permalink)
Alright, I went ahead and figured out the answer to my own question. For anybody else who decides to put the European switch on their bike, this is how to make the flash to pass trigger work.
When I opened up the switch, I noticed that the low/high beam switch itself had a red wire and a yellow wire connected to it. The flash to pass trigger also had the same exact red wire and a white wire. Coincidently, there is only 1 red wire at the wiring harness connector itself which led me to believe that these 2 red wires must splice together somewhere before they get to the connector plug.
I removed all of my fairings last weekend when I changed the oil and spark plugs and I left them off so I could wire up this switch as soon as I received it in the mail. Additionally, I had to remove a small plastic piece from the right side of bike which was located right by the bottom of the gas tank. After removing it, I could see approximately 3-4 wiring harness connectors right behind it. 1 of them was the wiring harness for this switch!
I disconnected the old switch and plugged in the new switch. All of the original buttons worked plus the hazard button worked immediately without any modification; however, the flash to pass trigger did nothing at all as was expected. I started the bike up and used a volt/ohm meter to test for current. I found out that the red wires which go to the low/high beam switch and flash to pass trigger have ~14 volts running to them. My understanding led me to believe that the current from the red wire needs to get to the yellow wire in order to complete the circuit to turn on the high beams.
Simple enough right? I took a paper clip and held one end to the white wire and the other to the yellow wire from the top side of the harness connector. After I did that, I pulled the trigger and the high beams lit up!!
So in order to make the flash to pass trigger work, all you have to do is splice the white wire to the yellow wire. I'm probably going to do it right down near the wiring harness connector so it is hidden underneath the tank instead of having some hacked up looking switch. It also makes sense for me to do it in this location so I can run the wires from there to my garage door opener and keep the wires tucked away where they cannot be seen.
I hope this helps for anybody else who wants to add the European switch to their bike!
Old 02-21-2008, 01:02 PM   #3 (permalink)
Big Deezul's Avatar
Big Deezul's Garage
Trader Rating: (34)
can you take some pictures to go along with your write up?
Big Deezul is offline   Reply With Quote
Old 02-27-2008, 07:04 PM   #4 (permalink)
Smile
Here are the pics I took. I got the wire splicers from Home Depot.
