Originally Posted by whizzkid
I'm trying to remove the AIS from my '05 r6, and I'm wondering how to remove the air box. it looks like it's screwed on from the bottom and I don't want to jack it up. Thank in advance for the help!!
Look under your air box. You will see the throttle bodies. There are clamps that hold rubber boots to the the TBs. (one per TB) A 4mm hex head should loosen these right up and the box will pop right off. You will have to loosen two from the right side and two from the left. Well, provided you removed your Ram Air ducts coming from the front.
There are also a couple hoses (AIS) going into the box. They come up from the bottom and are about 5/8 inch. These have spring clamps on them.
But I assume, since those are pretty easy to see, that its the TB clamps gicing you fits.
The screws you see in the bottom of the box hold the rubber TB boots to the air box. Don't take these out to remove the box. The only time you will want to take those out is if you put in Velocity stacks. (I recomend Factory Pro super flares)
