Springfield ArmoryCheapCycleParts.comSportbikeTrackGearSuperbikeToyStore.comHardRacing.comRacerPartsWholesaleAdvanstarMotorcycleShowsMotorcycle.com Classifieds!BikeBanditMotorcycle.com
Springfield Armory
Old 02-07-2007, 02:28 PM   #1 (permalink)
Ride Hard Take Chances
plasticweld's Avatar
plasticweld's Garage
Default a how to video body work and painting
This is a long video series that goes over these topics
Decal removal, Road rash repair. Plastic welding. Body fillers, Primers. Body panel prep, Gas tank dent removal. Primer steps, Wet sanding. Sealers, Paint, Graphics. Clear Coat, Polishing and buffing.
If you are doing your own work and need help please feel free to contact me, I will be glad to pass on what I know...Bob
contact info here
EmpireGP.com
This is the 3 min short version to see if it might be something you are interested in, in the long version just click on the bottom of the page to go to the next screen.
http://www.gotcanyons.net/gctheme.htm
The customer created this in-depth documentary.
Documentary starts from crash and includes every decision making process to decide how to repair fairings.
Documentary includes video utilizing voice-over for all repair sections.
Use the links at the bottom of each page to continue the documentary.
You can find the Documentary here:
http://www.gotcanyons.net/empiregp/intro.htm
Bob Brown
CSBA 284
EmpireGP.com Sportbike plastic welding, custom paint, tank repair
Ride Hard Take Chances We Need the Work
For a free quote on repair
Sales@EmpireGP.com
plasticweld is offline   Reply With Quote
Old 02-07-2007, 02:31 PM   #2 (permalink)
<- Lapped By Tracker
XxDevilR6xX's Avatar
XxDevilR6xX's Garage
Sweeeet!
"Driven By My Passion...Fueled By My Devotion..."
-The Calm Before The Storm-
XxDevilR6xX is offline   Reply With Quote
Old 02-07-2007, 02:52 PM   #3 (permalink)
voodoor6's Avatar
voodoor6's Garage
this would have been AWESOME about a month ago. :thumbs up though
07 R6..done painting..
voodoor6 is offline   Reply With Quote
Old 02-07-2007, 02:53 PM   #4 (permalink)
Don'tTazeMe,Bro!
sideshow's Avatar
sideshow's Garage
Trader Rating: (6)
"take it to the canyons"
sideshow is offline   Reply With Quote
Old 02-07-2007, 10:30 PM   #5 (permalink)
Navy Guy
HenryF's Avatar
HenryF's Garage
cool sent you an email with a question on gas tank dent repair.
www.actracing.com
HenryF is offline   Reply With Quote
Old 02-07-2007, 10:57 PM   #6 (permalink)
killrain's Avatar
killrain's Garage
Badass!!!!!!!!!!
killrain is offline   Reply With Quote
Old 02-08-2007, 10:37 AM   #7 (permalink)
Default how to pull a dent out of your tank
After getting a message from HenryF here on the site asking about the process of pulling a dent out and writing it all out for him I decided to make this into a how to with pictures so others may benifit from the same advice.
if you live in an area that is built up you should be able to go to just about any body shop and have them weld the pins they use pulling the dents on your car they are the same ones used to pull the ones on your tank, If you can not find someone here is a basic how to on how to pull them yourself. If you can find someone willing to do this instead of doing it yourself I would recommend it, For those guys who want to do all there own work here is some helpfull hints on performing the task
Here are some of the tools you will need.
Spot welding gun, pins, slide hammer. Ball peen hammer, Punch. Board Sander. Air nozzle, soapy water in a spray bottle, not shown air compressor and regulator and wire feed welder
There are some draw backs to finding someone to do it, their concerns will be that the tank will blow up, They Are Very Real!!, make sure the tank is dried out, have them run some compressed air through the tank so no fumes can build up. This is as important for you as it is for someone who may be working on a tank for the first time. I often let a tank sit with air blowing through it for 20 minutes just to be safe.
This is a picture of a friend of mine and fellow custom painter, he cut some corners and paid the price, over the years I have blown up two tanks both times from rushing, This can be done safely but you have to treat what your doing with some measure of common sense. You can be seriously hurt or killed doing this.
It takes many pins to pull a dent, the average baseball size dent it is not un-common for it to take 8 to ten pulls to get it to move, use the slid hammer only five or six times at the most to pull on the tank, then cut it off and weld another. I often start on the outside edge and move in when pulling.
Also the concern for pulling the pin through and leaving a hole in the tank so that it has to be welded shut should be considered, it does not happen a lot but it does happen and you are more likely to do so while figuring out how hard you can pull on the tank, It is important to keep the tank as solid as possible, the dent will pull easier and you will be less likely to put a hole in it. Once you have welded on the tank to fill any holes you will have to pressurize the tank to make sure there are no leaks, not that tough just block off the openings and put about 10 psi of air in to the bottom opening and then check with soapy water for any bubbles. The best rule of thumb is to use more pins less pulls, it will safe you the trouble of trying to weld up the hole you just made
Next is the hard part...High spots on the tank are what make repairing them difficult. if you imagine a crater from a bomb the hole is there and around the hole is the edges which are now higher then they were originally, Once you have pulled the dent you will have to hammer down the edges so that you can do body work, The best way to find the high spots is to use a flat sanding board and go over the area that was pulled and see what shiny spots show up. Take a hammer and a punch and lower them maybe a 1/8 inch or more. Put on your first coat of mud and then repeat the process. While this all sounds very simple, high spots in the tank will make it impossible for you to get your body work to look right. Often times it is just one small high spot that will give you tons of grief
This high spots are shown in this picture, you can see the shiny spots after going over it with a board sander
Once I am happy with the body work I then use a polyester primer to fill in any minor imperfections, it normally takes about 5 coats of primer, I sand inbetween the 4 and 5 coat with 120 grit and then 220 and then prime again
The finished tank
If your intersted in having us pull the dents and do the body work it is not that expensive, just let me know when you send me a note so that I can give you the board discount..Bob
Bob Brown
CSBA 284
Sales@EmpireGP.com
Old 02-14-2007, 12:40 AM   #8 (permalink)
L_R6_A's Avatar
L_R6_A's Garage
Trader Rating: (8)
Very nice. How long have you been doing repair work?
You should do a write up on color sanding too, that tends to be the hardest thing, after prepping, and the one thing I tend to avoid. C-side did a good write up, but I would like to see your techniques.
AZUSA BOYS IN THE HOUSE!
L_R6_A is offline   Reply With Quote
Old 02-14-2007, 09:30 AM   #9 (permalink)
deacon flicka
csideblue's Avatar
csideblue's Garage
Trader Rating: (25)
I can vouch for Bob's work. he knows what he's doing and was really cool in answering any questions i had when i began painting.
I sent a few tanks to be done but the dents were so deep they couldn't be saved so we shot em'
god write-up man
WERA West Novice #831
Originally Posted by Jonathan
csideblue is offline   Reply With Quote
Old 02-14-2007, 12:05 PM   #10 (permalink)
There is a long version that goes over some of the details in the long video of the on some of the how to's concerning color sanding.
The bottom line is that anyone learning how to do it will ruin more things than doing any other steps in the painting process, It is the only thing that when you screw up you are back to the beginning. I don't recommend that anyone learn as they go. I have personally ruined tons of parts that all had to be done all over again. It is done by feel, it depends on how much clear was applied. The only way to learn what is to far to sand down to is to sand down to far..
Bob Brown
CSBA 284
Sales@EmpireGP.com
