09-25-2006, 07:25 PM
Motorcycle Headlight Aiming
Getting a correctly aimed headlight is straightforward. You need to make a couple of measurements and then aim the light at a flat wall, as follows:
With the bike on its wheels and you astride, have a helper measure the distance from the floor to the center of the headlight lens.
Pick a flat wall where you can locate the bike so the headlight is 17 feet from the wall. Place a horizontal mark on the wall two (2) inches lower than the height of the center of the headlight.
The headlight beam (on low beam) should be relatively flat on the top, and may rise rather sharply at the right edge. Adjust the headlight vertically so that the flat top of the beam is just up to that line (marked two inches down at 17 feet).
Horizontal adjustment should center the beam ahead of the line of the bike.
By..... RLemmon
10-01-2006, 01:05 PM
StealthR6S
can you ajust the high beam, i put hid in the bike and i wanna have low and high on , but high is so much brighter, and i heard it is cause the wayy the headlight ,lense is or sumtin is there anythng i can do to maken them look the same
10-01-2006, 10:33 PM
Too poor to wheelie.
this how to, is weak. And is not really a how to at all.
02-16-2007, 11:25 AM
RLemmon: are you claiming that you wrote this when another member posted it before you did? lmao
Paul Glaves
02-16-2007, 04:52 PM
Certified Nut
erm This is incomplete, doesn't include any pictures, and doesn't even show where the headlight adjustments are. It also doesn't specify the adjustment of the bright's or possibly how to properly adjust them with the highbimmin/sea's modded lights...
And yes, BLACK is the fastest color!
02-16-2007, 04:59 PM
Nice catch. This how-to blows my balls...stolen or not.
02-16-2007, 08:40 PM
i know we've given this guy a hard time about this how-to. but it did me the info that i was looking for when i did the search. i know where the adj screws are and which way to turn them so the info that he gave is the part that i was missing.
02-16-2007, 08:49 PM
Guessin this is only for the projector headlights to right?
02-16-2007, 09:07 PM
yea, their is no way to adj headlights on 99-02 models.
02-17-2007, 06:04 PM
Gixxer rider
I'm suprised you still post here RLemmon, you got ripped into pretty good the last time you posted pics here. Which all seem to be deleted now.
