CheapCycleParts.comAdvanstarMotorcycleShowsSpringfield ArmoryMotorcycleToyStoreMotorcycle.comMotorcycle.com Classifieds!BikeBanditATV.comSportbikeTrackGear
Go Back   R6Messagenet.com > Yamaha YZF-R6 > R6 General
Old 08-26-2008, 12:05 PM   #1 (permalink)
DrummerDave's Garage
Default Mine's got a nasty headshake
03 R6.
Every time I cut the throttle at about 55 I get a nasty headshake.
History:
I just bought the bike. The PO says it has never been dropped, wrecked, anything. There is no evidence to suggest otherwise.
When riding, there's a slight constant wobble in the bars, like the front tire is out of balance. At 55, chop the throttle and the headshake comes.
If I take my hands off, they get a nice 3 to 4" shake.
Tires are Conti Road Attacks.
The front tire is pretty much shot, so that's my first suspect as the cause of the headshake.
Anything else I should check? Are R6s prone to headshake?
I do a lot of trackdays. Should I go ahead and get a damper?
2003 R6 - Nearly Stock.
2003 SV1000 - GSXR Forks & Shock, Gel seat, hugger, seat cowl, frame fliders, etc. For Sale!
1999 SV650 - Scorpion High mount, 636 Shock, Upgraded fork springs, SS lines, and a bunch of other stuff.
DrummerDave is offline   Reply With Quote
Old 08-26-2008, 11:29 PM   #2 (permalink)
M SOUZA
rbr6rider's Avatar
rbr6rider's Garage
tighten the head bearings, there is a how to on it.
rbr6rider is offline   Reply With Quote
Old 08-27-2008, 12:04 AM   #3 (permalink)
Big Deezul's Avatar
Big Deezul's Garage
Trader Rating: (34)
if it is happening when you chop the throttle either the steering head is loose OR the front tire is bad, or a combo of both. A true head shake comes from the frt being light not loaded
Big Deezul is offline   Reply With Quote
Old 08-28-2008, 02:11 PM   #4 (permalink)
I'll replace the tire and tighten those bearings.
Thx
Old 09-03-2008, 09:22 PM   #5 (permalink)
HardmanGT's Garage
Thx
Just tighten the head bearings and see how it is before spending money on a tire you most likely don not need. I had a similar issue some time ago that was cured after tightening.
HardmanGT is offline   Reply With Quote
Old 09-10-2008, 07:17 PM   #6 (permalink)
jyli19's Avatar
jyli19's Garage
After you park you bike, if your steering drops in to the left (lock position) by itself, tighten the steering head (not the just top nut, but the double locking ringnuts under the triple). - Cost you nothing is you can do it yourself
Check your fork setup to see if both sides are in balance, preload, rebound, compression. - Cost you nothing yet
Check you rear wheel alignment. - Still costs nothing
Check tire balance - $10 at local shops
Remove your fork and rotate them on a vise, check if they bent. - might cost half an arm if you got bend forks.
Good luck
jyli19 is offline   Reply With Quote
Old 09-10-2008, 07:19 PM   #7 (permalink)
jyli19's Avatar
jyli19's Garage
oh yeah, definitely get the damper if you extra $$. since I put on the Ohlins, haven't seen a headshake yet
Old 09-18-2008, 01:36 PM   #8 (permalink)
BlueDevilD's Avatar
BlueDevilD's Garage
yup tighten head berrings and make sure your front tire is in good condition and air pressure is correct.
Damper: ehh dont usually need a damper unless you are wheeling or track riding a lot on a 6.. but thats a whole diff issue... Its NOT needed to fix THIS prob for sure
BlueDevilD is offline   Reply With Quote
