Motorcycle.comBikeBanditMotorcycle.com Classifieds! McCoyMotorsportsSportbikeTrackGearATV.com - Write Your Review and Win!
Go Back   R6Messagenet.com > Yamaha YZF-R6 > Oil and Lubrication
McCoyMotorsports
Old 12-27-2008, 11:52 PM   #11 (permalink)
Flowing Free
tsefreeflow's Avatar
tsefreeflow's Garage
You dont have to remove the drain bolt if you need to lower the level some. I used a siphen hand pump once that would fit in the dipstick hole and got a 1/2 to 1 quart out very quick and clean.
1990 300ZX Twin Turbo Highly Modified
2005 Yamaha R6 Slightly Modified
tsefreeflow is offline   Reply With Quote
Old 06-27-2009, 07:05 PM   #12 (permalink)
2008R6Raven
2008R6777's Avatar
2008R6777's Garage
Originally Posted by iaresev View Post
My bike takes barely over 2 quarts to fill, it's a 2008.
Get the service manual and double check for your bike.
Hello mine is a 2008 R6 and it takes 3 quarts give or take a little.
2008R6777 is offline   Reply With Quote
Old 07-03-2009, 11:45 AM   #13 (permalink)
J Law's Garage
~3 quarts is standard
J Law is offline   Reply With Quote
Old 07-11-2009, 02:46 PM   #14 (permalink)
www.frontiercycle.com
jebova2301's Garage
Whenever I fill my bike, I pour all three quarts in. I do a lot of wheelies though, and when you do, you pull the oil away from the sump a bit. I would always feel safer with my engine running with a little more oil than it needs as opposed to a little less. Remember, your oil pump will only pull so much. If there is more than enough, it will just draw what it needs. If there isn't enough, it can't pull all it should, and your motor doesn't get enough oil.
jebova2301 is online now   Reply With Quote
Old 07-20-2009, 11:16 AM   #15 (permalink)
r6mkp's Avatar
r6mkp's Garage
2.5 qts will put it at the very top of the hatch marks on my 02 r6 ...and that's after being warmed up. 3qts would defenitly be too much (on my bike anyway).
r6mkp is offline   Reply With Quote
Old 08-04-2009, 06:20 PM   #16 (permalink)
JonskyGBR's Avatar
JonskyGBR's Garage
BE CAREFUL, having too much oil in the sump is not a good idea! If you overfill it enough you risk the crankshaft hitting the surface of the oil, and that's bad.
Keep it Polished
JonskyGBR is offline   Reply With Quote
Old 08-04-2009, 10:21 PM   #17 (permalink)
jebova2301's Garage
Ok. So I changed my oil today. I always use a new filter. I drained all the oil. Took of the filter...let the last bit drain out. Then I used maybe an ounce or two as cleanout oil(just enough to get the last old oil to dribble out). Long story short, I poured in 2 quarts, and most of the remainder from that other bottle(cleanout oil bottle...about 30oz left). I poured in close to 24oz of that, and went for a ride. Came home and let the bike sit for a few minutes, and checked the oil level. It was at the bottom on the dipstick. Added the rest of he oil...rode a bit more...checked again. This time, is was about 2mm below the top of the notches on the dipstick. I say to basically run the 3 quarts if you have an 03-05 or the R6s. On the R model, I would run what it says. I don't think that little extra is going to do any harm. But in the end, it is ultimately up to you.
Old 08-20-2009, 05:40 AM   #18 (permalink)
www.leatherbull.com
leatherbull's Garage
too much oil in the sump isn't good
http://www.leatherbull.com
leatherbull is offline   Reply With Quote
Old 10-17-2009, 08:09 PM   #19 (permalink)
volumebikertom's Garage
Spec is 2.85 quarts, but putting 3 quarts in wont hurt anything, any more than 3 quarts and you might run into some oil aeration issues.
mmmmmmmmmmsstt aaaaaaaahh
volumebikertom is offline   Reply With Quote
Old 11-02-2009, 08:29 PM   #20 (permalink)
Site Sponsor
Amsoil Dealer Group's Avatar
Amsoil Dealer Group's Garage
According to the Page I have copied out of Yamaha manuals, it calls for 2.75 qts..
3 is overfilled.... Aeration is caused by an oil not having the proper anti-foaming additives.
Overfilling can cause blown seals and oil consumption..
The proper quantity IS in every manual..
The Best isn't cheap
Cheap isn't The Best
Bob
We offer special prices and all products are shipped from the closest AMSOIL warehouse. For more info go to www.bestoil4you.com or 1-877-356-6099.
Motorcycle Oil test data links http://www.bestoil4you.com/files/g2156MCoilStudy.pdf ..... Gear Lube Study http://www.bestoil4you.com/files/g2457GearLube.pdf
Amsoil Dealer Group is offline   Reply With Quote
Harley Davidson Suzuki GSXR Ducati Forum Kawasaki Forum Sportbikes Forum
V-Rod Forum GSXR Forum Ducati Monster Vulcan Forums Triumph Forum
Harley Forum Suzuki SV Honda 600RR Kawasaki ZX Forum Triumph 675
Buell Forum Yamaha R1 Honda 1000RR Kawasaki ZX-10R Can Am Spyder
KTM Forum Yamaha R6 Honda Fury Forums Kawasaki KLR 650 Aprilia Forum
Victory Forums YZF-R6 Forum Honda Goldwing Kawasaki Versys BMW S1000RR Forum
