CheapCycleParts.comSportbikeTrackGearMotorcycle.comRacerPartsWholesaleSpringfield ArmoryATV.comAdvanstarMotorcycleShowsMotorcycle.com Classifieds!Adaptiv Technologies LLCBikeBandit
Go Back   R6Messagenet.com > Site Sponsors > Group Buys & Sponsored Sales
CycleGear.com
Old 06-07-2007, 12:02 AM   #1 (permalink)
Site Sponsor
Cal-Sportbike's Avatar
Cal-Sportbike's Garage
Trader Rating: (13)
Default June Cal-Sportbike Specials
New Cal-Sportbike specials...good through 6/30/2007...
KBC FORCE RR FULL FACE HELMETS
(Ret $159-189, Sale $129-159!)
http://www.calsportbike.com/cgi-bin/...=Helmets_-_KBC
KBC is an American company with a head office in Los Angeles. KBC relentlessly strives to fuse the latest technological developments with stunning graphics to deliver unrivaled performance. All KBC products are precision engineered to deliver outstanding comfort, fit and safety.
- Hi Impact Solvent Resistant Alloy PC Shell.
- Reduced overall shell dimensions.
- New 2.2 mm 'OPCC' Scratch resistant visor.
- New KBC Ultra Quick Removal Visor mechanism (No Tools).
- New 'RIB' Visor Sealing Technique.
- Totally New fitment platform for ultimate wearer comfort
- Totally new internal comfort lining design for comfort and noise reduction - New Controllable Air Ventilation and Cooling System
- Meets or Exceeds All major worldwide safety standards and tests
__________________________________________________ _________________
EK/DRIVEN 520 CONVERSION POWER-UP KIT
(Retail $175-up...Sale $139-up)
http://www.calsportbike.com/cgi-bin/...x.cgi?pid=1728
The bolt-and-go 520 conversion power-up kit with colored rear HARDENED alloy sprockets and an X-ring EK chain! AND we are including a rivet link for maximum tensile strength. This kit drops TWO pounds of rotating mass and semi-sprung weight from an OEM steel 530 kit!). We've paired it with highly durable (AMA Supermoto and WSMC championships!) COLOR-anodized Driven sprockets in a -1/+2 race gearing package for out-of-the-box acceleration! While values will vary, a -1/+2 gearing change averages about 11% increase in rear wheel torque...while this lowers your top end a little, it produces incredible holeshot performance!
EK 520SRX CHAINS
A great bang-for-the-buck X-ring chain, the EK SRX is a sealed X-ring chain
* Your choice of standard dark gray or upgrade to gold
* 4 point riveting, thick side plates for long wear life
* Solid bushings and rollers
* ONLY SUGGESTED FOR 600/750cc BIKES
* Suggested for street riding use
* Tensile strength rated at 8500lbs
EK 520MVXZ CHAINS
* For 600-1000cc streetbike use
* Larger pin diameters make this chain stronger and longer lasting
* X-rings have greater sealing surface
* Tensile strength rated at 9000lbs
EK 520RXO CHAINS WITH ZST ("zero-stretch technology")
* For street and roadracing usage
* Strongest, lightest, and smoothest chain from EK
* Each link has low-friction X-Ring
* Isothermal heat treatment allows use of thinner side plates for lighter weight WITH increased tensile strength.
* Tensile strength rated at 9300lbs
DRIVEN SPROCKETS
Made in the USA from 7075 T-6 Aluminum by CNC and hobbing machine, balanced and tested for trueness. The final process is color hard anodizing for appearance and surface protection against corrosion.
Driven sprockets are machined to tolerances no greater than 0.2mm, which is less than half of OEM standards (smaller is better).
PIPERCROSS PERFORMANCE AIR FILTERS
(Free 3-day air shipping during the sale!)
http://www.calsportbike.com/cgi-bin/...oduct=Air-Fuel
New to the US market, but one of the most dominant air filters in the European market, Pipercross gives you increased power and torque, is easy to clean/reuse, and carries a lifetime warranty.
Pipercross works with leading race teams like Rizla Suzuki and Factory Ducati, not to mention automotive marques such as Aston Martin, Cosworth, M-Sport WRC, Lotus, Mercedes, and TRD.
Pipercross foam is the secret to a lightweight, longlife performance air filter. Pipercross air filters consistently outperform paper and cotton-gauze rivals to supply air to the engine - even when dirty! This is thanks to the multilaminate construction used in every Pipercross performance air filter. Layers of varying porosity foam all work together to trap different sized particles. Air filter efficiency testing Through extensive research and testing using the SAE J726c air cleaner test, Pipercross have developed the perfect combination of filter density and thickness of each layer. Where Pipercross filters are impregnated with the dirt retention additive, the filtration performance is greater enhanced - the additive helps the foam to swell, opening pores whilst providing a "sticky" layer to hold more dirt. This greater dirt capacity translates to longer life and as Pipercross filters are washable, there is no waste - helping the environment and your wallet!
Pipercross has been making high performance air filters for the motorsport and domestic market for over 28 years. Based in Northampton, England, Pipercross are situated in the country along with some of the biggest names in motorsport engine design and manufacturing in the world. In these 28 years, their high performance filters have helped many race teams win major championships on the British, European and World stage. The development work carried out while dealing with these teams have enabled them to produce some of the technically advanced filters on the market.
Note: All special sales are final. No returns or exchanges on sale items. UPS Shipping rates apply unless "free shipping" is included. Idaho sales tax of 6% will be added for all shipments to buyers within Idaho.
Todd Robinson
Owner, Cal-Sportbike * Toll Free 877.234.5150 * Sagle, Idaho
sales@calsportbike.com * M-F 9AM-5PM
* Speedo Healer & GIPro, Galfer, Shogun, Pipercross Air Filters, Elka Suspension, Shoei
Cal-Sportbike is offline   Reply With Quote
Old 06-16-2007, 04:02 PM   #2 (permalink)
ride like u got a pair
benny6d9's Garage
u got a price for the filters? 04 R6 thanks
benny6d9 is offline   Reply With Quote
Old 06-16-2007, 09:05 PM   #3 (permalink)
Chrisbr's Garage
I was looking and for yamaha you dont offer the 99-02 520 conversion...is there any chance its available but its just not showing up?
Chrisbr is offline   Reply With Quote
Old 06-17-2007, 03:21 AM   #4 (permalink)
Site Sponsor
Trader Rating: (13)
In the Driven sprockets, we only get it for the 03+ model R6, sorry. I can do AFAM for the older bike, but it's not on special right now...
Todd Robinson
Old 06-17-2007, 04:14 PM   #5 (permalink)
Chrisbr's Garage
Thats fine man. I just really wanted to take advantage of the gold colored sprocket deal.
